Tools
How to enable Wake On LAN (WOL) in DRE
Learn how to enable the Wake-on-LAN feature in DRE
6/7/2019 5:40 PM
6/7/2019 5:40 PM
  • Is there a Wake-On-LAN feature with DRE?
  • Steps on how to enable WOL on DRE.
Dameware Remote Everywhere
  • Wake-On-LAN is one feature exclusively available in TDRE.
  • This feature is only available on Windows Agents.
  • The requirements for this feature are:
    1. Ensure Wake On Lan is supported on both local and remote devices - some laptop computers do not support WOL, or only support it while on AC Power. Some power supplies for desktop computers may also be incompatible;
    2. The computer BIOS also needs to be correctly set up. Look for a WOL option and enable it. This option may have different names (“Resume from my PCI Device”, for instance), depending on the motherboard and BIOS version. If different options exist with similar names, test each one to find the correct option;
    3. Make sure both DRE console and DRE remote agents are updated to their latest version.
  • For further details on the WOL feature, please check the help guide here .
