How to enable Dark Theme for NOC views for SolarWinds Platform 2025.1 and above
This article provides walkthrough on how to enable dark theme for NOC views.
8/11/2025 3:43 PM
8/11/2025 3:43 PM
Dark Mode in NOC is only available for Modern Dashboards.
Network Performance Monitor
  1. Open the SolarWinds Platform Web Console and log in with admin credentials.
  2. Navigate to Settings > All Settings > Views Section > Manage Dashboards/Views.
  1. Filter NOC enabled view & Modern.
  1. Select View & Edit.
  1. At the top right corner > Click on the middle icon > Edit NOC View Setting.
  1. A pop-up will appear, and you can select 'Dark Mode'.
