Applications Systems
How to display all components polled for each polling engine in SAM
This article describes how to run an SQL query to show how many components are being polled in SAM. If running SAM with component-based licensing, this value can be higher than the licensed component count displayed in the SolarWinds Platform Web Console.
As described in Check the number of available component monitors in my SAM license, you can see how many available component monitors remain in a component-based SAM license by navigating to Settings > All Settings > SAM Settings and clicking SAM License Summary.
Note: SolarWinds now offers node-based SAM licensing. See the SAM licensing model for details.
You can also view that information on the main License Details page, but neither page breaks out component data for individual polling engines. Another way to see licensing details is described in Report for component licenses by SAM.
This article describes how to run an SQL query to determine all components polled for each polling engine. This value is usually higher than the licensed component count displayed in the SolarWinds Platform Web Console.
- Log into the SolarWinds Platform Server.
- Open Database Manager. (See Use Database Manager to view the SolarWinds database for details.)
- Run a query listed below.
Query 1:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT Count(ccs.ApplicationID) [Component Count], e.EngineID, ae.ServerName, ae.ServerType FROM [dbo].[APM_CurrentComponentStatus] ccs JOIN [APM_Application] ap ON ccs.ApplicationID = ap.ID JOIN [Nodesdata] node ON ap.NodeID = node.NodeID JOIN [Engines] e ON node.EngineID = e.EngineID JOIN [Engines] ae ON ae.EngineID = e.EngineID GROUP BY e.EngineID, ae.ServerName, ae.ServerType ORDER BY [Component Count] DESC
Query 2:
The following query lists only non-disabled components of non-unmanaged application monitors count per poller:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT Count(cc.ApplicationID) [Component Count], e.EngineID, ae.ServerName, ae.ServerType FROM [dbo].[APM_Component] cc JOIN [APM_Applications] ap ON cc.ApplicationID = ap.ID JOIN [Nodes] node ON ap.NodeID = node.NodeID JOIN [Engines] e ON node.EngineID = e.EngineID JOIN [AllEngines] ae ON ae.EngineID = e.EngineID where isdisabled is null and ap.Unmanaged = 0 GROUP BY e.EngineID, ae.ServerName, ae.ServerType ORDER BY [Component Count] DESC
Query 3:
The following example query determines if there are a large number of components in a single monitor type (such as AppInsight monitors):
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT Count(*) AS 'num' FROM [APM_CurrentComponentStatus] WHERE ApplicationID in (select ID from [dbo].[APM_Application] WHERE Name like '%iis%') ORDER BY num desc;
Query 4:
The following query lists the application IDs that are polling a large number of components:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT ccs.ApplicationID, ap.Name, Count(ccs.ApplicationID) Component_Count, node.Caption, e.EngineID FROM [dbo].[APM_CurrentComponentStatus] ccs JOIN [APM_Application] ap on ccs.ApplicationID = ap.ID JOIN [Nodesdata] node on ap.NodeID = node.NodeID JOIN [Engines] e on node.EngineID = e.EngineID GROUP BY ap.Name, ccs.ApplicationID, node.Caption, e.EngineID ORDER BY Component_Count DESC
Query 5:
The following query lists all the components and their current status:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT n.Caption AS NodeName, a.Name AS ApplicationName, c.Name AS ComponentName, ccs.ErrorMessage AS ComponentErrorMessage FROM APM_CurrentComponentStatus ccs JOIN APM_Component c ON ccs.ComponentID = c.ID JOIN APM_Application a ON c.ApplicationID = a.ID JOIN NodesData n ON a.NodeID = n.NodeID WHERE ccs.Availability != '1' AND (ccs.ErrorMessage IS NOT NULL AND ccs.ErrorMessage != '')
Query 6:
The following query lists components count per node without unmanaged nodes/applications and disabled components:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT n.Nodeid, n.Caption, count(c.id) as Count FROM nodes n JOIN APM_Application a on n.nodeid=a.nodeid JOIN APM_Component c on a.id=c.applicationid where IsDisabled is NULL and a.Unmanaged = 0 and n.UnManaged = 0 GROUP by n.nodeid, n.caption order by count desc
Query 7:
The following query lists applications and their components per node without unmanaged nodes/applications and disabled components (use it in SQL Management Studio):
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT n.Nodeid, n.Caption, a.name, c.name FROM nodes n JOIN APM_Application a on n.nodeid=a.nodeid JOIN APM_Component c on a.id=c.applicationid where IsDisabled is NULL and a.Unmanaged = 0 and n.UnManaged = 0 GROUP by n.nodeid, n.caption, a.name, c.name
Query 8:
The following query lists applications and their polling frequencies (both the setting at the template level and at the application level). If you include the last line, query results will include applications polling under 300 second (default) intervals:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT a.ID, a.Name, a.NodeID, a.TemplateID, asg.Value AS [Application Setting], ats.Value AS [Template Setting] FROM [dbo].[APM_Application] a LEFT JOIN [dbo].[APM_ApplicationTemplateSetting] ats ON (ats.ApplicationTemplateID = a.TemplateID AND ats.[Key] = '__Frequency' ) LEFT JOIN [dbo].[APM_ApplicationSetting] asg ON (asg.ApplicationID = a.ID AND asg.[key] = '__Frequency') WHERE (asg.Value IS NOT NULL OR ats.Value IS NOT NULL) --AND (asg.Value < '300' OR ats.Value < '300')
The following query can be used to determine the number of used component monitors and licensed component monitors for individual polling engines:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT e.EngineID, CASE WHEN at.CustomApplicationType IS NULL THEN 'Generic Applications' WHEN at.CustomApplicationType = 'ABAA' THEN 'Active Directory AppInsights' WHEN at.CustomApplicationType = 'ABSA' THEN 'SQL AppInsights' WHEN at.CustomApplicationType = 'ABIA' THEN 'IIS AppInsights' WHEN at.CustomApplicationType = 'ABXA' THEN 'Exchange AppInsights' WHEN at.CustomApplicationType = 'ABTA' THEN 'WSTM AppInsights' ELSE at.CustomApplicationType END as ApplicationType, COUNT(c.ID) as TotalComponents, CASE WHEN at.CustomApplicationType = 'ABAA' THEN (SELECT COUNT(*) * 50 FROM [SolarWindsOrion].[dbo].[APM_Application] as a INNER JOIN [SolarWindsOrion].[dbo].[APM_ApplicationTemplate] as at ON a.TemplateID = at.ID WHERE at.CustomApplicationType = 'ABAA') -- Active Directory AppInsights WHEN at.CustomApplicationType = 'ABSA' THEN (SELECT COUNT(*) * 50 FROM [SolarWindsOrion].[dbo].[APM_Application] as a INNER JOIN [SolarWindsOrion].[dbo].[APM_ApplicationTemplate] as at ON a.TemplateID = at.ID WHERE at.CustomApplicationType = 'ABSA') -- SQL AppInsights WHEN at.CustomApplicationType = 'ABIA' THEN (SELECT COUNT(*) * 30 FROM [SolarWindsOrion].[dbo].[APM_Application] as a INNER JOIN [SolarWindsOrion].[dbo].[APM_ApplicationTemplate] as at ON a.TemplateID = at.ID WHERE at.CustomApplicationType = 'ABIA') -- IIS AppInsights WHEN at.CustomApplicationType = 'ABXA' THEN (SELECT COUNT(*) * 50 FROM [SolarWindsOrion].[dbo].[APM_Application] as a INNER JOIN [SolarWindsOrion].[dbo].[APM_ApplicationTemplate] as at ON a.TemplateID = at.ID WHERE at.CustomApplicationType = 'ABXA') -- Exchange AppInsights WHEN at.CustomApplicationType = 'ABTA' THEN (SELECT COUNT(*) * 5 FROM [SolarWindsOrion].[dbo].[APM_Application] as a INNER JOIN [SolarWindsOrion].[dbo].[APM_ApplicationTemplate] as at ON a.TemplateID = at.ID WHERE at.CustomApplicationType = 'ABTA') -- WSTM AppInsights ELSE COUNT(c.ID) END AS LicensedComponents FROM dbo.APM_Component AS c INNER JOIN dbo.APM_Application AS a ON c.ApplicationID = a.ID INNER JOIN [dbo].[NodesData] as n ON a.NodeID = n.NodeID INNER JOIN dbo.Engines as e ON n.EngineID = e.EngineID LEFT JOIN dbo.APM_ComponentTemplate as ct ON C.TemplateID = ct.ID LEFT JOIN dbo.APM_ApplicationTemplate as at ON ct.ApplicationTemplateID = at.ID WHERE C.Retained = 0 AND (ISNULL(ct.VisibilityMode, 0) = 0 OR (ct.VisibilityMode = 2 AND C.ApplicationItemID IS NOT NULL) OR ct.VisibilityMode = 3) GROUP BY e.EngineID, at.CustomApplicationType
