Applications Systems
How to disable alerts for Virtual Clusters from being triggered both on Nutanix and VMware clusters
When an alert has a trigger condition for Virtualization Cluster objects, or for child entities (hosts, VMs, datastores, virtual disks, etc.) that exist as part of both a VMware cluster and a Nutanix cluster, this alert can be triggered twice, once for VMware and once for Nutanix.
For example, if you have an alert on a Virtualization Cluster that triggers when one of the cluster’s hosts is in a critical state, the alert will trigger twice (once for VMware, once for Nutanix) if the host is part of both a VMware and a Nutanix cluster.
- Add an additional trigger condition to the alert for the property "Virtualization Platform" of the “Virtual Cluster” object,
- Set it to the type of cluster you want to trigger the alert on, “VMware” or “Nutanix”, depending on your desired behavior.
Note: The Virtualization Platform option also exists for Virtual Host and Virtual Machine object types. However, the Virtual Cluster object type must be selected for the Virtualization Platform condition.
Tip: If you are using an out-of-the-box alert that has duplicated behavior, you can disable the out-of-the-box alert, make a copy of the alert, and add the trigger condition as described above.
