Security Compliance
How to disable WSUS auto approvals
This article describes how to disable WSUS auto approvals in Patch Manager.
- Open the WSUS Administration Console.
Click Start > All Programs > Administrative Tools > Microsoft Windows Server Update Services. - Go to Options > Automatic Approvals.
- Deslect Default Automatic Approval Rule.
- Click OK.
See Configure automatic approvals using the WSUS Administration Console for more information. (© 2018 Microsoft Corporation, available at http://www.microsoft.com/, obtained on March 15, 2018)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
