How to disable HTTP methods in IIS
This article explains how to disable the HTTP such as TRACE, TRACK, PUT, and DELETE methods in IIS. These methods can be flagged as unsafe by vulnerability assessments as dangerous HTTP Methods
| IIS Version | TRACE | TRACK |
| 7 | Disabled | Disabled |
| 8.5 | Enabled | Disabled |
| 10 | Disabled | Disabled |
IIS allows you to filter HTTP commands and deny any TRACE or TRACK methods. This article explains how to create these filters.
HTTP TRACK, TRACE, PUT and DELETE can be used to leverage other attacks.
How to deny an HTTP verb:
- Go to IIS Manager
- Select the Orion website
- Select Request Filtering
- Select HTTP Verbs
- Select Deny Verbs...
- Enter TRACE and click OK
Do this for TRACK, PUT and DELETE
Save the changes
You can also follow the Microsoft steps here
(© 2020 Microsoft, available at https://docs.microsoft.com/en-us/iis/configuration/system.webserver/security/requestfiltering/, obtained on 04, 29 day, 2020)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third-party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
