How to determine if an alert triggered in SolarWinds platform
Sometimes customers believes that an alert did not trigger, by using querying the data from DB we can confirm if an alert triggered.
1/18/2020 5:04 PM
10/24/2025 9:53 PM
This servers as a guide on how to determine if an alert triggered by querying the AlertID of a specific alert and filtering the entries in AlertHistoryView using the AlertID.
Orion Platform
1. RDP to the SolarWinds Platform server.
2. Launch Database Manager from the SolarWinds Platform folder of the Start menu.
3. Click Add Orion Server.
4. Expand the SQL instance and SolarWinds database in bold.  Locate the AlertConfigurations table.
5. Right-click the table and select Query table.
6. Locate the alert via the Name column then determine its corresponding AlertID.
7. Query the AlertHistoryView(View) and filter the results using the AlertID.
Sample:
Select * from AlertHistoryView
where AlertID = 'xx'
(where xx is the AlertID)
8. Using the TimeStamp as a reference, determine if the alert was triggered.
