Database Management
How to delete a target in SQL Sentry
This article will walk through the process of how to delete a target within SQL Sentry.
3/4/2024 3:45 PM
3/3/2025 10:26 PM
This process may vary depending on the type of target that is currently being watched. The example will be based on a SQL Server target. Each target may have 1 or more nodes that will need to be unwatched before the target can be deleted.
SQL Sentry (SQLS)
  1. Stop watching the SQL Server Instance node by right-clicking and going to Stop Watching.
  2. Stop watching the Windows node by right-clicking and going to Stop Watching.
  3. Once the entire target shows a gray icon, you can right-click and select Delete Target.
