How to configure a recurring Maintenance Schedule for nodes in SolarWinds Platform 2025.2
This article helps with how to set up a recurring maintenance schedule.
8/6/2025 4:25 PM
8/6/2025 4:25 PM
Starting from SolarWinds Platform 2025.2, you can now set up, assign, and manage recurring maintenance suppression schedules all directly from the Web Console.
Network Performance Monitor
Create the Maintenance Schedule
  1. Navigate to Settings > All Settings > Manage Maintenance Schedules
  2. Click on Add
  3. Populate all the required fields
  1. To save changes, make sure to click on "Confirm Schedule"
Assign the created Maintenance Schedule
  1. Settings > Manage Nodes
  2. Select one or more nodes > Maintenance Mode > Schedule
  3. Change Maintenance frequency to Recurring, then click on ASSIGN SCHEDULES
  1. Assign one or more schedules to the selected nodes
  2. Click "Schedule" to save changes and assign the schedules
You can then view the list of schedules and the assigned nodes on the schedules on the Manage Nodes page.
