Tools
How to configure Admin Area permissions for Dameware Remote Everywhere
Steps for configuring Dameware Remote Everywhere Admin Area permissions
- How to configure Dameware Remote Everywhere Admin Area permissions.
- Login to your Admin Area.
- Navigate to Management>Technicians.
- Select the intended technician.
- Select the PERMISSIONS tab.
- Choose the ADMIN AREA sub tab.
- Set the options as intended for this technician.
- You may also select a preset profile from the top left corner.
- Click the Save button.
