How to clear triggered instance of alert from the Orion Web Console
Clear triggered instance of alerts from the Manage Alerts page.
Alerts are not automatically cleared.
- Log in to the Orion Web Console.
- Click Alerts & Activity > Alerts.
- Select the check box next to the alert or alerts you want to clear.
- Click Clear Triggered Instance of Alert.
The alert is cleared. -
If the problem that triggered the alert still exists, the alert should re-trigger after the device is polled again.
