How to clear triggered instance of alert from the Orion Web Console
Clear triggered instance of alerts from the Manage Alerts page.
10/25/2018 11:42 AM
10/19/2022 3:42 PM
This article explains how to clear triggered instance of alert from the Orion Web Console.
Orion Platform
Alerts are not automatically cleared.
  1. Log in to the Orion Web Console.
  2. Click Alerts & Activity > Alerts.
  3. Select the check box next to the alert or alerts you want to clear.
  4. Click Clear Triggered Instance of Alert.
    The alert is cleared.
  5. If the problem that triggered the alert still exists, the alert should re-trigger after the device is polled again.
