Tools
How to change the TLS protocol in Web Help Desk
This article describes how to change the Transport Layer Security (TLS) protocol for a Web Help Desk deployment.
This article describes how to enable TLS 1.1 in the Apache Tomcat server configuration file.
- Stop Web Help Desk.
Navigate to the following directory:
<WebHelpDesk>\conf -
Back up the tomcat_server_template.xml file to a separate location.
If you encounter any issues, you can revert to the original settings. - Open the tomcat_server_template.xml file in a text editor (such as Notepad).
- Locate the WEBHELPDESK_SSL_PORT settings.
- Locate sslProtocol in the file. There are two occurrences in the file.
Add TLSv1.1 to the first occurrence.
Change:
clientAuth="false sslProtocol="TLS" sslEnabledProtocols="TLSv1.2"
to
clientAuth="false sslProtocol="TLS" sslEnabledProtocols="TLSv1.1, TLSv1.2" - Repeat step 7 for the second occurrence.
- Save the file.
- Start Web Help Desk.
Verify the TLS version
Verify the TLS version using a Google Chrome or Mozilla Firefox web browser.
Google Chrome
- Log in to Web Help Desk.
- Right-click the Web Help Desk interface and select Inspect.
- In the toolbar, click Security.
Under Security overview, scroll down and review the connection details.
Mozilla Firefox
- In the Address bar, click the icon to the left of the URL.
- Click More Information.
- Click the Security tab.
Scroll down to Technical Details and review the TLS version.
