Tools
How to Setup SMTP configuration in Serv-U using Office 365
This article describes on how to Setup SMTP configuration in Serv-U using Office 365
11/6/2018 3:25 PM
5/26/2026 4:50 PM
Serv-U application has an option to Configure an SMTP connection to send an email for events which are configured to use email actions. The Serv-U supports default port for encrypted SMTP connections is 465 and supports Implicit SSL only.
However, since Office 365 requires TLS Encryption, which is Explicit SSL/TLS (port 587) encryption only, this article describes how Office 365 SMTP Server will work in Serv-U Application.
Serv-U does not support Explicit SSL/TLS (port 587). Some SMTP servers support Explicit SSL/TLS (port 587) encryption only. Therefore it is not possible to configure these servers in Serv-U directly.
In order to setup the Office 365 SMTP server with TLS in Serv-U, configure your server with SMTP relay. Contact Dedicated Office 365 Administrator to SMTP relay connector.
External link for references:
How to set up a multifunction device or application to send email using Office 365 and Microsoft 365. To read more, click here.
