How to Recreate the SolarWinds-Orion certificate
This article covers on how to re-create the Solarwinds-Orion certificate that is used for communication on every solarwinds server.
10/11/2018 3:54 PM
5/27/2025 10:42 PM
Sometimes it is necessary to recreate the SolarWinds-Orion Certificate. It may become corrupted, or some servers may not have the correct certificate.
Orion Platform
To recreate the SolarWinds-Orion certificate:
  1. Run the mmc (e.g. from the Start menu).
  2. Click File > Add/Remove Snap-in.
  3. In the left pane, select Certificates, and then click Add.
  4. Select Computer Account (for LocalMachine), click Next, and then click Finish.
  5. With the Certificates Snap-in added, click on it to open it up.
  6. Go to Personal > Certificates and select the SolarWinds-Orion certificate.
  7. Right click on it and then export it and the private key just in case it is needed.
  8. Delete the SolarWinds-Orion certificate. It is not advised to remove any other certificate, as it can cause issues.
  9. Run the Configuration Wizard. The wizard will recreate the SolarWinds-Orion certificate.
For more information:
