How to Rebuild UDT Jobs
This article walks through the steps required to rebuild UDT jobs when they get stuck.
- Connect to the Orion server.
- Open Orion Service Manager from the Solarwinds Orion folder of the start menu.
- Stop all Orion services via Orion Service Manager.
- Launch Database Manager from Start > All Programs > SolarWinds Orion.
- Click on Add Default Server to connect to the SQL server hosting the Orion Database.
- Expand your SQL Server and identify the Orion Database in bold.
- Right-click the Orion Database and click on New Query. Paste the following:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. Truncate Table UDT_Job
- Press Execute Query.
Solarwinds Platform 2020.2.6 and lower
- Go to C:\ProgramData\Solarwinds\Installers
- Note: ProgramData is a hidden folder, please make sure that the "Show hidden files, folders, and drives" option is enabled on Folder Options.
- Right-click JOBENGINE-2.xx.x.xxxx-JobEngine.v2.msi and click Uninstall - Please note that file names may differ by version.
- Right-click COLLECTOR-2.xx.x.xxxx-CollectorInstaller.msi and click Uninstall - Please note that file names may differ by version.
- Right-click JOBENGINE-2.xx.x.xxxx-JobEngine.v2.msi and click Install - Please note that file names may differ by version.
- right click COLLECTOR-2.xx.x.xxxx-CollectorInstaller.msi and click Install - Please note that file names may differ by version.
- In Orion Service Manager, select Start Everything to start all services.
Solarwinds Platform 2022.2 and above
Collector:
2. Stop the SolarWinds Collector via the Orion Service Manager on all Orion servers.
3. Navigate to C:\ProgramData\Solarwinds\Collector\Data.
4. Delete the PollingController.db and PollingController.db-journal files.
5. Start the service once more via the Orion Service Manager.
6. The files will be rebuilt automatically.
Job Engine:
1. RDP to the Orion Server.
2. Stop the SolarWinds Job Engine via the Orion Service Manager on all Orion servers.
3. Navigate to C:\ProgramData\Solarwinds\JobEngine\Data.
4. Delete the JobEngine.db and JobEngine.db-journal files.
