Tools
How to Hide the Dameware Mini Remote Control Agent System Tray Icon
The Dameware Mini Remote Control (MRC) Agent has a system tray icon where you can access its settings. When you make changes to the agent settings (usually through group policy), a message says that the MRC Agent is reconfiguring. You can hide the icon to disable the message.
- On the target machine, right click the MRC Agent icon and click Settings.
- Go to the Additional Settings tab.
- Uncheck the option Show Tray Icon.
OR
- Open the registry editor.
- Go to HKEY_LOCAL_MACHINE\SOFTWARE\DameWare Development\Mini Remote Control Service\Settings
- Modify/Edit
DWORD TrayIcon to value = 0 (value = 1 enables or makes visible the tray icon)
The registry key method is useful for deploying the settings through a group policy.
If the MRC Agent system tray is still not hidden:
- On the target machine, right-click Remove service.
- Re-install service on the configuration setting.
- Uncheck the Show Tray Icon option.
