How to Create a Custom SQL Report in the Orion Web Console
The article covers the best approach to creating custom SQL/SWQL reports.
Log into your Orion web console as an administrator with Report Management Rights.
- Navigate to Settings > All Settings > Manage Reports > Create new report
- Choose Custom Table > select and continue
- Choose the third option in the drop-down for the Selection method: Advanced Database Query (SQL, SWQL)
- Choose the correct radio button depending on if you plan to use SQL or SWQL.
- Enter your query. You may preview your results but it is recommended to develop your SQL script using an appropriate platform such as Database Manager, SWQL Studio, or SQL Server Management Studio.
- Select the columns in the report
Utilize these platforms to develop your SQL scripts.
- Use Database Manager to view the SolarWinds database
- SQL Management Studio Direct Download Link
- Download the SolarWinds Orion SDK and start using SWQL
**NOTE: SolarWinds support does not develop, configure, or implement custom scripting of any kind:
- Support does not include the development of custom scripts, reports, templates, SQL queries, perform analysis of or troubleshoot performance problems related to third-party products, or SQL or Operating System issues.
