How do I estimate how many flows per second my device is sending
How do I estimate how many flows per second my device is sending?
To find out what your flows per second average is for a specific time frame:
- Log on to the appropriate device.
- Execute clear ip flow stats in the CLI prompt.
- Wait the appropriate time.
- Run show ip cache flow after the appropriate time elapses.
Note: The commands might differ depending on your device and its IOS version. Check with your vendors configuration guide for appropriate commands.
