Tools
How To Create Automated or Recurring Reports in the Service Desk - ITSM
This article lists the steps on how to configure a pre-generated report that is scheduled to be sent depending on the customer's preferred frequency.
3/14/2023 11:46 AM
3/14/2023 11:46 AM
Service Desk
When a customer asks how to create reports that get sent regularly to specific groups or users.
From the service desk homepage, go to Analytics > Reports and select the report template based on the data needed.
  1. Generate the data for the particular report, then click Save as New and specify the Report Name, then click Save.
.11  Incidents Over  as New  View many incidents were  Created/aSSigned/reSOlved"etC. per  chosen time frame, stacked by your  field of •merest  Thi S information Can be used  answer questions sucn as: Knar is tne  weekty of noden,t5 trend mat
  1. Once saved, click the menu button and select Schedule Report.
  1. From here, you can specify who will receive the report and the frequency of when the report is generated.
Related documentation: https://documentation.solarwinds.com/en/success_center/swsd/content/completeguidetoswsd/analytics-reports.htm
