How Rediscovery Works in the SolarWinds Platform
This article explains how Rediscovery works in the SolarWinds Platform web console.
8/23/2019 8:04 AM
7/9/2025 9:23 PM
The concept behind Rediscovery is to poll only device data that is not prone to frequent changes (hence the default 30 mins interval between rediscovery polls). Examples of such data are Vendor, System Name, or MAC/IP addresses. In addition, Rediscovery is used to run remapping for all interfaces/volumes to get updated interface/volume indexes.
It's worth noting that Rediscovery of Parent Entity also automatically initiates rediscovery of its child objects (e.g. rediscovering a Node also rediscovers its Volumes and Interfaces).
Orion Platform
-Rediscovery will update information populated into the Node Details section if this has changed in the SNMP configuration on the node or DNS changes around the node name when doing a look up against the IP. This will also force a Topology rediscover if you select Layer2/Layer3 resources when adding the node to the SolarWinds Platform, and update changes to volumes or interfaces if they are changed after the initial addition of the node.
- 30 minutes is the default interval.
These are the affected tables and columns when rediscovering:
NodesData
Caption
SysName
SystemObjectID
IOSImage
IOSVersion
Vendor
VendorIcon
MachineType
Description
Contact
Location
Category
IsServer
Vendor, VendorIcon, MachineType, IOSImage, IOSVersion
are not affected for UCS and VIM nodes
NodesStatistics
NextRediscovery
LastSync
Volumes
NextPoll
Status
VolumeResponding
NextRediscovery
FullName
VolumeIndex
DeviceId
DiskSerialNumber
SCSITargetId
SCSIPortId
SCSILunId
SCSIControllerId
SCSIPortOffset
DeviceId, DiskSerialNumber, SCSITargetId, SCSIPortId, SCSILunId, SCSIControllerId, SCSIPortOffset
are updated only for WMI volumes
NodeIPAddresses
NodeID
IPAddress
IPAddressN
InterfaceIndex
IPAddressType
SubnetMask
During each rediscovery session whole table is repopulated for particular node
NodeMACAddresses
NodeID
MAC
DateTime
Interfaces
InterfaceType
InterfaceIcon
InterfaceSpeed
InterfaceMTU
PhysicalAddress
DuplexMode
FullName
IfName
Caption
InterfaceAlias
NextRediscovery
Topology tables---
Entire tables are updated:
NodeCiscoCdpEntries, NodeL2Connections, NodeL3Entries, NodeL3RoutingData, NodeLldpEntries,
NodePortInterfaceMap, PortItems, STPRecords tables are populated according to assigned pollers
