Applications Systems
High Player Load on Player Location and Transactions Not Playing
Transactions are not playing. Transactions are unknown. Player location show over 100% player load. High player load on the server.
%ProgramData%\SolarWinds\Logs\SEUM\AgentService.Log
Look for failure to create worker process message near the latest entry:
ERROR SolarWinds.SEUM.Agent.WorkerProcessManagement.WorkerProcessLauncher - Error launching worker process.
System.Exception: Error launching worker process. Error: logon error. System error: 0x569
at SolarWinds.SEUM.Agent.WorkerProcessManagement.WorkerProcessLauncher.LaunchWorkerProcessInCurrentSession()
at SolarWinds.SEUM.Agent.WorkerProcessManagement.WorkerProcessLauncher.LaunchWorkerProcessInternal()
ERROR SolarWinds.SEUM.Agent.WorkerProcessManagement.WorkerProcessManager - Unable to create worker process. Trying again.
Example of high player load
- RDP to the affected player location.
- Start > Run > compmgmt.msc
- Local Users and Groups > Groups > Administrators > [right-click] properties.
- Edit the Administrators group > click on 'Add...' > Click on 'Locations...'
- Change the location to the server. Click the server name then click OK.
- Click 'Advanced' > Click 'Find Now'
- Shift-click all SEUM users from the list and once highlighted, click OK. Then click the next OK.
- Click Apply.
