Tools
Hide maintenance banners in Dameware
This article provides steps on how to remove maintenance banners in Dameware.
Note: You may need to create the HKEY_LOCAL_MACHINE\SOFTWARE\DameWare Development key.
Warning: SolarWinds strongly recommends that you back up your registry before making any edits to your system registry. You should only edit the registry if you are experienced and confident in doing so. Using a registry editor incorrectly can cause serious issues with your operating system, which could require you to reinstall your operating system to correct them. SolarWinds cannot guarantee resolutions to any damage resulting from making registry edits.
Hiding Maintenance Banners
You can hide the maintenance banner that ensures you have enough warning before your maintenance period expires. Edit the registry and enter one of the values for Show Maintenance Banner:
0 - No one will see the maintenance banners. The maintenance period may expire without your knowledge.
1 - Only administrators see the maintenance banners.
2 - All users see the maintenance banners.
Modify the registry for Dameware Remote Support or Mini Remote Control applications (these instructions apply to all installations except when the 32-bit version of Mini Remote Control is installed on a 64-bit computer):
Option 1
- Press the Windows key + R, and type regedit.
- Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\DAMREWARE Development.
- Create a new DWORD value, and name it Show Maintenance Banner.
- Enter the data for the DWORD value:
- Right-click the value, and then select Modify.
- In the new DWORD value field, enter the data.
Option 2
Note: 0 is the value that disables the maintenance banner.
- Open CMD with administrative rights.
- Run the command:
cmd /c reg add "HKLM\SOFTWARE\DameWare Development" /v "Show Maintenance Banner" /t REG_DWORD /d 0 /f
Modify the registry for 32-bit Mini Remote Control applications installed on a 64-bit computers:
Option 1
- Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Dameware Development.
Option 2
- Open CMD with administrator rights.
- Run the command:
cmd /c reg add "HKLM\SOFTWARE\Wow6432Node\DameWare Development" /v "Show Maintenance Banner" /t REG_DWORD /d 0 /f
Hide Integration Banners
You can hide the integration mode banners that indicate you are using a limited version of MRC by opening the application through the Web Help Desk. Edit the registry, and enter one of the following values for Show WHD Banner.
0 - No one will see the banners.
1 - Only administrators see the banners.
2 - All users see the banners.
Option 1
- Navigate to HKEY_LOCAL _MACHINE\SOFTWARE\Dameware Development.
- Create a new DWORD value, and name it Show WHD Banner.
- IN the new DWORD value field, enter the data.
Option 2
Note: 0 is the value that disables the WHD banner.
- Run the command:
cmd /c reg add "HKLM\SOFTWARE\DameWare Development" /v "Show WHD Banner" /t REG_DWORD /d 0 /f
To modify the registry for 32-bit Mini Remote Control applications installed on 64-bit computers:
Option 1
- Enter the data for the DWORD value. To do this:
Option 2
- Run the command:
cmd /c reg add "HKLM\SOFTWARE\Wow6432Node\DameWare Development" /v "Show WHD Banner" /t REG_DWORD /d 0 /
Note: When the maintenance banner settings are modified in the registry and a different user runs the Dameware program without permission to read the registry, the settings will not take effect.
