Hardware polling failed: Polling of chassis (CIM_Chassis class) failed. Unable to establish session with all provided credentials error in SAM
Hardware polling failed: Polling of chassis (CIM_Chassis class) failed. Unable to establish session with all provided credentials shown on all the host under Virtualization summary
This article describes the issue when you receive following error:
- Enable the SNMP polling on this ESXi host to monitor the Hardware health:
- Monitor the ESX host using Vcenter as VCenter has the CIM client:
Alternative Solution: Change Polling Status to go through V-Center Server instead of Direct to Host.
