Applications Systems
Hardware Health is not working for VMware ESX host
For Server & Application Monitor (SAM) all versions, Hardware Health is not working on the VMware ESX host. This article provides a workaround.
10/11/2018 2:32 PM
5/1/2020 12:51 PM
Server Application Monitor
ESX
Restart CIM services by running the following commands
service sfcbd stop
service sfcbd start
ESXi
Restart the CIM provider by running the following commands:
esxcli system settings advanced set -o /UserVars/CIMProviderName -i 0
esxcli system settings advanced set -o /UserVars/CIMProviderName -i 1
Restart the SFCBD agent by running the following command to allow the changes to take effect.
/etc/init.d/sfcbd-watchdog restart
If the customer is using VMware 8.0.0, the commands are the following:
esxcli system wbem set -e true
esxcli system wbem get
/etc/init.d/sfcbd-watchdog status
