Hardware Health: SAM and NPM differences
This quick guide explains the difference between Hardware Health for Server & Application Monitor (SAM) and Network Performance Monitor (NPM).
10/30/2018 3:07 AM
4/20/2022 4:30 AM
  • SAM Hardware Polling:
    • SAM can monitor hardware (servers) from VMware hosts, HP ProLiant, Dell PowerEdge, and the IBM X-Series.
    • Hardware monitoring is achieved by polling via SNMP, WMI, or VMware API, depending upon the node
  • NPM Hardware Polling:
    • NPM polls hardware health only for network devices, such as routers and switches using SNMP.
SAM (Server HWH Sensors)
  • [APM_HardwareInfo] (SAM)
    • 0 Unknown
    • 1 VMware                Direct ESX polling (CIM polling)
    • 2 SNMPDell
    • 3 SNMPHP
    • 4 SNMPIBM
    • 5 VMwareAPI          (Through vCenter VMware API)
    • 6 WmiDell
    • 7 WmiHP
    • 8 WmiIBM
NPM (Networking HWH Sensors)
  • [HWH_HardwareInfo]  (NPM)
    • 9 Snmp.NPM.Cisco (2 Different MIB Options)
    • 10 Snmp.NPM.Juniper
    • 11 Snmp.NPM.HP
    • 12 Snmp.NPM.F5
    • 14 Snmp.NPM.Dell.PowerConnect
    • 18 SNMP.NPM.Arista
    • 19 SNMP.NPM.ASA
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
