Handle custom properties with NULL and 'empty' values in alert conditions
For Network Performance Monitor (NPM), conditioned alerts on custom property values must explicitly handle NULL and empty value cases.
10/30/2018 2:40 AM
2/3/2023 10:27 AM
Due to the distinction in how SQL Server handles NULL and 'empty' values as table entries, alerts that are conditioned on custom property values must explicitly handle both the NULL and 'empty' value cases.
Orion Platform
This is due to how SQL handles empty & NULL values.
When building an alert condition that uses the value of a custom property, as follows:
  Trigger when any of the following apply:
  Custom_property is not equal to 'foo'
explicitly specify alert conditions to handle the distinction SQL Server makes between NULL and 'empty' entries, as follows:
  Custom_property is not equal to 'foo'   Custom_property is empty
This article applies to all SolarWinds Orion products using alerts and custom properties.
