Tools
HTTPS 501 not implemented error when accessing the web client
This article addresses an issue that generates a "501 not implemented" error when you access the web client.
10/26/2018 7:07 PM
10/26/2018 7:07 PM
When you access the web client, the following error displays:
501 not implemented
This could be an issue with the load balancer.
  1. If the HTTPS ports on the server are listening, telnet to the server and check for a response.
  2. Access the web client internally direct to the MFT server. If accessible, MFT is not an issue.
  3. Access the web client internally direct to the Serv-U Gateway. If accessible, the gateway is not an issue.
  4. If the issue occurs when accessing externally, this is a network issue. Serv-U is working properly.
  5. Check your firewall or load balancer configuration.
  6. Check the SSL offloading setting on the load balancer.
  7. Check the load balancer certificate.
