Applications Systems
"Type is not resolved for member 'SolarWinds.APM.Logging.Log4net.SwLogicalPropertiesContext,SolarWinds.APM.Logging" error in HTTP form monitor on Agent nodes
This article discusses an issue with HTTP Form Monitor in SolarWinds SAM which fails when using the Agent polling method, displaying the error: "Type is not resolved for member 'SolarWinds.APM.Logging.Log4net.SwLogicalPropertiesContext,SolarWinds.APM.Logging'."
7/9/2025 4:24 PM
10/21/2025 9:09 PM
This article addresses the issue where the HTTP Form Monitor in SolarWinds Server & Application Monitor (SAM) fails when using the Agent polling method, resulting in the error: "Type is not resolved for member 'SolarWinds.APM.Logging.Log4net.SwLogicalPropertiesContext,SolarWinds.APM.Logging'."
This error typically indicates a problem with the SolarWinds APM (Application Performance Monitor) component, specifically related to the Log4net logging framework used by the agent.
Application Centric Monitor
This is a known issue in SAM 2025.1 and 2025.2.
This issue is fixed in SAM 2025.4. Consider upgrading your environment. If you can't upgrade, please use an agentless polling method as a workaround.
