Applications Systems
HTTP Bindings monitor 401 authentication error when changing authentication settings in Configuration Wizard
This article resolves an issue when the HTTP Binding monitor stops working with a 401 authentication error when changing the authentication setting using the Configuration Wizard on an agent-polled AppInsight for ISS node. The monitor stops working when running the Configuration Wizard and selecting Windows authentication, when the node has an agent installed with No-Manual authentication set.
To resolve, you need to do the following:
- You will need a domain user account with access to the affected IIS sites through HTTP.
- Click Settings > SAM settings > Global SAM Settings > Credentials Library. Add the user to credential library in Orion.
- Open AppInsight for IIS and click Edit Application settings.
- Locate the HTTP Bindings Monitor.
- Set Credentials for monitoring to the added domain user. This should make the HTTP monitors for all IIS sites use the domain user for authentication.
If you want to use a different user for each site's HTTP monitor, you can set it in a similar way repeating per site:
- Open the site details in AppInsight for IIS.
- Edit thresholds.
- Locate the HTTP Bindings monitor.
- Access the Credentials for Monitoring > Override Instance.
- Set the user account.
