Group status not displaying correctly
The Group status is not displaying the correct status even when the Status rollup mode for the group has been set correctly to Mixed, Best or Worst status. NPM 10.6.
The Group status is not displaying the correct status even when the Status rollup mode for the Group has been set correctly to Mixed, Best or Worst status.
This occurs when the data it references, in this case the ContainerMembersnapshots table, is out of date and needs to be refreshed.
- Open the Database Manager application.
- Select Add Server.
- Expand the Database server and then the SolarWinds database.
- Right-click and query any table.
- Clear the existing 'Select Top * from ........'
- Enter
Delete from ContainerMemberSnapshots
- Execute the query.
- Test the group status in the web console after refreshing the page.
