Group dependencies are not working in Orion Platform
Group dependencies are not working as expected
(If the poller name or IP is changed or the Dependencies table contains old or incorrect data that the table needs to remove and the table will be re-populated automatically)
- Open the Orion Database Manager.
- Select the default server.
- Expand the SolarWinds database.
- Right-click the database, and then select New Query.
- Enter the following query:Disclaimer:
Delete from containermembersnapshots
- Execute the query.
Note: This table will be re-populated automatically as the groups are used
