GPO is blocking Powershell and impacting Orion Upgrade
Some GPO configured can prevent the content.psd1 Powershell file from being executed and it impacts the Orion installer.
"Files may have been modified or corrupted, please contact our support team. "F:\content.psd1 error: System.ComponentModel.Win32Exception: This program is blocked by group policy. For more information, contact your system administrator."
Note, the issue is mostly observed in Offline installation scenarios.
You can check if some GPOs are blocking Powershell by running the following command in the Orion server.
#gpresult
It can show a result like this:
(Screenshots property of Microsoft Corporation © 2023 Microsoft Corporation)
Disable the GPO that is preventing Powershell from being executed and rerun the installer.
Resolution 2:
If you can't disable the GPO temporarily at least, then:
1. Mount the Offline ISO
2. Copy SolarWinds.Installer.exe and all contents of SubInstallers folder to (C:\ProgramData\SolarWinds\Installers)
3. Go to Settings > My Deployment > Update to use the Centralized web console-based update tool to upgrade.
