Fortinet login validation tests fail with a $ as a prompt
Test Failed timeout in Fortigate devices.
Use device credentials in NCM that have full Admin/Root access. These credentials return a # as the prompt.
Another way to fix the problem is to add to the device template using the following command:
<Command Name="VirtualPrompt" Value="$"/>
For more information, click on this link on how to modify a device template for NCM version 7.4: Modify a default device template in NCM 7.4
