Forcing the Business Layer to load plugins in a separate or 64-bit process
Enabling ForcePluginsInSeparateProcess when encountering system out of memory exception for the main business layer module
10/29/2018 2:28 AM
1/17/2025 11:03 PM
This article provides information about changing the Business Layer (Module Engine) behavior to load plugins as separate processes, as opposed to a single process (default). It is especially beneficial in large or complex environments having OOM (Out-Of-Memory) issues.
Orion Platform
Resolution 1
  1. Log in to the Orion Web Console.
  2. Access the Centralized Settings feature by adding the following to the URL:
    <OrionServer>/Orion/Admin/AdvancedConfiguration/Global.aspx
    For example:
    <server_name>:8787/Orion/Admin/AdvancedConfiguration/Global.aspx
  3. Select the GLOBAL tab to apply the setting to all servers, or select the SERVER-SPECIFIC tab to select a specific server.
  4. Scroll down to the section SolarWinds.BusinessLayerHost.BusinessLayerHostSettings and locate the ForcePluginsInSeparateProcess setting.image.png
Orion version 2024.1 onwards it would be located under BusinessLaterHostimage.png
  • True - Always use separate processes.
  • False - Always use a single process.
  • Auto (default) - If enough memory (8 GB) is installed and the Orion database is not on the same machine, separate process are used
    5. Click Save.
    6. Restart the Orion Services.
Resolution 2
You can run the following query in the Orion DB:
  1. Stop the Orion services.
  2. Run the query below.
INSERT INTO Setting (Name, Value) VALUES ('SolarWinds.BusinessLayerHost.BusinessLayerHostSettings.ForcePluginsInSeparateProcess', 'True')
  1. Restart the Orion Services
