Tools
Filters in Kiwi Web Access interface are slow
This article describes the issue when attempting to use filters within the Kiwi Web Access interface, the results take a long time to produce, it shows a timeout or only gets a day of logs
10/18/2018 8:37 PM
10/18/2018 8:37 PM
When you attempt to use filters within the Kiwi Web Access interface, the results take a long time to produce or it shows a timeout.
Kiwi Syslog Server
This issue may occur due to the following reasons:
  1. The database has reached its maximum size, which is 4 Gigabytes.
  2. Kiwi Syslog Server is continuously inserting large amounts of data to the Kiwi Web Access database.
  3. The Top 50 matches are rare, which requires Kiwi Web Access to search the entire 4 Gigabyte database.
Here are few recommendations to improve filtering times in the Kiwi Web Access interface based on the scenarios outlined above:
  1. Reduce the amount of data being inserted into the Kiwi Web Access database by adding Filters to the "Log to Kiwi Web Access" rule within the Kiwi Syslog Service Manager. For example, you can add a Priority Filter to only log syslog messages with a priority of Warn or higher.  More information on configuring filters is found here: Kiwi Syslog Server - Sample Filter
  1. Reduce the number of rows that need to be retrieved per page.
    1. Login to the Kiwi Web Access interface.
    2. Click the Settings tab.
    3. Set the Rows Per Page to a lower integer, such as 10.
  1. Reduce the size of the database.
    2. Click the Admin tab.
    3. In the Database Maintenance section, decrease the Maximum Database Size to a lower integer, such as 2048 MB (2 Gigabytes).
