Filter and suppress alerts
This article describes how to configure an alert that is triggered when a node switches its status from Down to Up.
- Go to Trap Viewer > Alerts/Filter Rules.
- Either edit your existing syslog rule/alert or create a new alert.
- Enter the values based on the name of the node alert that needs to be filtered in the following tabs:
- Message
- Severity
- Trigger Threshold
- Select the severity level.
- Specify the alert action under the Alert Actions tab.
