Feature availability based on monitoring methods — with agents or agentless using SNMP, WMI, or WinRM
The following table displays a comparison of which features are available for the Windows agent versus agentless.
This article provides a comparison of which features are available for the Windows agent versus agentless. SNMP is typically used to monitor servers and network devices without agents. For Windows servers, Windows Management Instrumentation (WMI) can usually provide a better set of metrics than can be obtained through SNMP monitoring alone. For many Windows-based servers and applications, agentless monitoring via the WMI gateway provides strong monitoring capabilities.
The availability of some features depends on which Orion Platform modules are in your environment, as well as which product versions you're using. For example, NPM supports polling via WMI, SNMP, and agents. However, interface polling via WMI and Agent is not supported unless you have a SAM license. You must use SNMP as a polling method to obtain interface data in an NPM-only installation. For details, see Polling methods used by Orion .
Environment
- Orion Platform products and SolarWinds Platform products
Detail
Windows agent |
WMI (agentless) |
SNMP (agentless) |
WinRM (agentless) | ||
| 1 | Node Name/Caption | Yes | Yes | Yes | Yes |
| 2 | Node Status | Yes | Yes | Yes | Yes |
| 3 | Response Time/Latency (ICMP) | Yes | Yes | Yes | Yes |
| 4 | Response Time/Latency (SNMP) | No | No | Yes | Yes |
| 5 | Response Time/Latency (Agent) | Yes | No | No | No |
| 6 | Packet Loss | Yes | Yes | Yes | Yes |
| 7 | IP Addresses | Yes | Yes | Yes | Yes |
| 8 | IP Address Type (IPv4 or IPv6) | Yes | Yes | Yes | Yes |
| 9 | Machine Type | Yes | Yes | Yes | Yes |
| 10 | DNS Name | Yes | Yes | Yes | Yes |
| 11 | Description | Yes | Yes | Yes | Yes |
| 12 | Location | Yes | Yes | Yes | Yes |
| 13 | Contact | No | No | Yes | No |
| 14 | Last Boot | Yes | Yes | Yes | Yes |
| 15 | Number of CPUs | Yes | Yes | Yes | Yes |
| 16 | CPU Usage | Yes | Yes | Yes | Yes |
| 17 | Individual CPU Core Usage | Yes | Yes | Yes | Yes |
| 18 | Memory Usage | Yes | Yes | Yes | Yes |
| 19 | Total Memory | Yes | Yes | Yes | Yes |
| 20 | Vendor | Yes | Yes | Yes | Yes |
| 21 | Availability | Yes | Yes | Yes | Yes |
| 22 | Quality of Experience (QoE) | Yes | No | No | No |
| 23 | Universal Device Poller | No | No | Yes | No |
| 24 | Device Studio/Custom Pollers | No | No | Yes | No |
| 25 | VMware Virtualization Monitoring (Basic) | Yes | Yes | Yes | No |
| 26 | Hyper-V Virtualization Monitoring (Basic) | Yes | Yes | No | No |
| 27 | Hardware Health | Yes | Yes | Yes | Yes |
| 28 | Asset Inventory | Yes | Yes | Yes | Yes |
| 29 | Real-Time Process Explorer | Yes | Yes | Yes | |
| 30 | PerfStack Real-Time Polling | Yes | Yes | Yes | Yes |
| 31 | Web-based SSH Client | Partial* | Partial* | Partial* | Partial* |
| 32 | Network Interface Monitoring - SAM | Yes | Yes | No | Yes |
| 33 | Network Interface Monitoring - NPM | No | No | Yes | No |
| 34 | Real-Time Service Manager | Yes | Yes | Yes | Yes |
| 35 | Real-Time Event Log Viewer | Yes | Yes | Yes | Yes |
| 36 | Reboot | Yes | Yes | No | Yes |
| 37 | Routing | No | No | Yes | No |
| 38 | Topology | No | No | Yes | No |
| 39 | Linux Load Average | No | No | No | No |
| 40 | Volume Name | Yes | Yes | Yes | Yes |
| 41 | Volume Status | Yes | Yes | Yes | Yes |
| 42 | Volume Type | Yes | Yes | Yes | Yes |
| 43 | Volume Size | Yes | Yes | Yes | Yes |
| 44 | Volume Space Used | Yes | Yes | Yes | Yes |
| 45 | Volume Space Available | Yes | Yes | Yes | Yes |
| 46 | Volume Percent Used | Yes | Yes | Yes | Yes |
| 47 | Volume Allocation Failures | No | No | Yes | No |
| 48 | Volume Avg. Disk sec/Transfer (Latency) | Yes | Yes | No | Yes |
| 49 | Volume Disk queue length | Yes | Yes | No | Yes |
| 50 | Volume Read I/O | Yes | Yes | No | Yes |
| 51 | Volume Write I/O | Yes | Yes | No | Yes |
| 52 | Volume Total IOPS | Yes | Yes | No | Yes |
| 53 | AppInsight for IIS | Yes | Yes | No | Yes |
| 54 | AppInsight for Exchange | Yes | Yes | No | Yes |
| 55 | AppInsight for SQL | Yes | Yes | Yes | Yes |
| 56 | DHCP User Experience Monitor | No | Yes | Yes | Yes |
| 57 | Directory Size Monitor | Yes | Yes | Yes | Yes |
| 58 | DNS Monitor - TCP | Yes | Yes | Yes | Yes |
| 59 | DNS Monitor - UDP | Yes | Yes | Yes | Yes |
| 60 | DNS User Experience Monitor | Yes | Yes | Yes | Yes |
| 61 | Download Speed Monitor | Yes | Yes | Yes | Yes |
| 62 | Exchange Web Services UX Monitor | Yes | Yes | Yes | Yes |
| 63 | File Age Monitor | Yes | Yes | Yes | Yes |
| 64 | File Change Monitor | Yes | Yes | Yes | Yes |
| 65 | File Count Monitor | Yes | Yes | Yes | Yes |
| 66 | File Existence Monitor | Yes | Yes | Yes | Yes |
| 67 | File Size Monitor | Yes | Yes | Yes | Yes |
| 68 | FTP Monitor | Yes | Yes | Yes | Yes |
| 69 | FTP User Experience Monitor | Yes | Yes | Yes | Yes |
| 70 | HTTP Form Login Monitor | Yes | Yes | Yes | Yes |
| 71 | HTTP Monitor | Yes | Yes | Yes | Yes |
| 72 | HTTPS Monitor | Yes | Yes | Yes | Yes |
| 73 | IMAP4 Monitor | Yes | Yes | Yes | Yes |
| 74 | IMAP4 User Experience Monitor | Yes | Yes | Yes | Yes |
| 75 | JMX Monitor | No | Yes | Yes | Yes |
| 76 | LDAP User Experience Monitor | Yes | Yes | Yes | Yes |
| 77 | Linux/Unix Script Monitor | N/A | N/A | N/A | N/A |
| 78 | MAPI User Experience Monitor | Yes | Yes | Yes | Yes |
| 79 | Nagios Script Monitor | No | No | No | No |
| 80 | NNTP Monitor | Yes | Yes | Yes | Yes |
| 81 | ODBC User Experience Monitor | Yes | Yes | Yes | Yes |
| 82 | Oracle User Experience Monitor | Yes | Yes | Yes | Yes |
| 83 | Performance Counter Monitor | Yes | Yes | Yes | Yes |
| 84 | POP3 Monitor | Yes | Yes | Yes | Yes |
| 85 | POP3 User Experience Monitor | Yes | Yes | Yes | Yes |
| 86 | Process Monitor | Yes | Yes | Yes | Yes |
| 87 | Process Monitor - Windows | Yes | Yes | Yes | Yes |
| 88 | RADIUS User Experience Monitor | Yes | Yes | Yes | Yes |
| 89 | Service Status - SNMP | No | No | Yes | No |
| 90 | SMTP Monitor | Yes | Yes | Yes | Yes |
| 91 | SNMP Monitor | No | No | Yes | No |
| 92 | SOAP Monitor | Yes | Yes | Yes | Yes |
| 93 | SQL Server User Experience Monitor | Yes | Yes | Yes | Yes |
| 94 | SSL Certificate Expiration Date Monitor | Yes | Yes | Yes | Yes |
| 95 | TACACS+ User Experience Monitor | Yes | Yes | Yes | Yes |
| 96 | TCP Port Monitor | Yes | Yes | Yes | Yes |
| 97 | Tomcat Server Monitor | Yes | Yes | Yes | Yes |
| 98 | VMware Performance Counter Monitor | Yes | Yes | Yes | Yes |
| 99 | Web Link Monitor | Yes | Yes | Yes | Yes |
| 100 | Windows Event Log Monitor | Yes | Yes | Yes | Yes |
| 101 | Windows PowerShell Monitor | Yes | Yes | Yes | Yes |
| 102 | Windows Script Monitor | Yes | Partial* | Partial* | Partial* |
| 103 | Windows Service Monitor | Yes | Yes | Yes | Yes |
| 104 | WMI Monitor | Yes | Yes | Yes | Yes |
| 105 | Application Dependencies (with SAM 6.0 and later) | Yes | No | No | No |
| 106 | Push Deployment - Add Node | Yes | N/A | N/A | N/A |
| 107 | Mass Deployment - Push from Web | Yes | N/A | N/A | N/A |
| 108 | Manual Installation | Yes | N/A | N/A | N/A |
| 109 | Pull Deployment - wget/curl/etc. | No | N/A | N/A | N/A |
| 110 | Mass Deployment - GPO/MSI | Yes | N/A | N/A | N/A |
| 111 | Mass Deployment - Puppet/Chef | No | N/A | N/A | N/A |
| 112 | Deployment via Repository | No | N/A | N/A | N/A |
| Cell | Detail |
| 31: Agent | "Partial" assumes the Orion Server or Additional Polling Engine (APE) the node is associated with has routable connectivity to the agent-managed node and that the Windows node is running an SSH Daemon, such as freeSSHd (© 2008-2015 Kresimir Petric, available at http://www.freesshd.com, obtained on December 4, 2018). The Web Based SSH Client communicates over TCP Port 22 from the Orion Server or APE to the selected node and does not utilize the agent communications channel. The Windows Operating System also does not include a native out-of-the-box SSH Server. Windows however, does provide an unencrypted Telnet service for similar functionality. Unfortunately, Orion's Web Based SSH client does not support Telnet at this time. |
| 31: WMI, SNMP | "Partial" assumes the Windows node is running an SSH Daemon, such as freeSSHd (© 2008-2015 Kresimir Petric, available at http://www.freesshd.com, obtained on December 4, 2018). The Windows Operating System does not include a native out-of-the-box SSH Server. Windows however, does provide an unencrypted Telnet service for similar functionality. Unfortunately, Orion's Web Based SSH client does not support Telnet at this time. |
| 102: WMI, SNMP | Windows Script Monitors run against SNMP or WMI managed nodes and execute locally on the Orion Server or Additional Poller through which the node is managed. These Windows Scripts do not execute on the managed node itself. To execute Windows Scripts on the node being managed, users must install the Orion Agent or rewrite their script in PowerShell utilizing WinRM. |
