SolarWinds Orion installer issue with Active Diagnostics compatibility
Some users may receive the following error message when attempting to upgrade using the new SolarWinds installer: Specified custom product/component [ACTIVEDIAGNOSTICS:1.7.0.378] or its higher version is already installed.
Some users may receive the following error message when attempting to upgrade using the SolarWinds Orion Installer:
- Uninstall the Active diagnostics by going to
C:\programdata\solarwinds\installers(hidden folder) - Locate the
SolarwindsActiveDiagnostics.msifile - Right-click this file and select Uninstall.
- Run the installer again.
