Tools
FTP Response Codes
A list of FTP response codes with links to detailed articles.
Following are links to the detailed articles for the FTP response codes.
- 110 FTP response code - Restart marker reply.
- 120 FTP response code - Service ready in nnn minutes.
- 125 FTP response code - Data connection already open; transfer starting
- 150 FTP response code - File status okay; about to open data connection
- 200 FTP response code - Command okay
- 202 FTP response code - Command not implemented, superfluous at this site
- 211 FTP response code - System status, or system help reply
- 212 FTP response code - Directory status
- 213 FTP response code - File status
- 214 FTP response code - Help message.
- 215 FTP response code - NAME system type.
- 220 FTP response code - Serv-U FTP Server v6.0 for WinSock ready...
- 221 FTP response code - Service closing control connection.
- 225 FTP response code - Data connection open; no transfer in progress.
- 226 FTP response code - Closing data connection.
- 227 FTP response code - Entering Passive Mode (h1,h2,h3,h4,p1,p2).
- 230 FTP response code - User logged in, proceed.
- 232 FTP response code - User logged in, authorized by security data exchange.
- 234 FTP response code - AUTH command OK. Initializing SSL connection.
- 250 FTP response code - Requested file action okay, completed.
- 257 FTP response code - "PATHNAME" created.
- 331 FTP response code - User name okay, need password.
- 332 FTP response code - Need account for login.
- 334 FTP response code - [ADAT=base64data]
- 336 FTP response code - Username okay, need password. Challenge is...
- 350 FTP response code - Requested file action pending further information.
- 421 FTP response code - Service not available, closing control connection.
- 425 FTP response code - Can't open data connection.
- 426 FTP response code - Connection closed; transfer aborted.
- 431 FTP response code - Need unavailable resource to process security.
- 450 FTP response code - Requested file action not taken.
- 451 FTP response code - Requested action aborted: local error in processing.
- 452 FTP response code - Requested action not taken.
- 500 FTP response code - Syntax error, command unrecognized.
- 501 FTP response code - Syntax error in parameters or arguments.
- 502 FTP response code - Command not implemented.
- 503 - Bad sequence of commands.
- 504 FTP response code - Command not implemented for that parameter.
- 530 FTP response code - Not logged in.
- 532 FTP response code - Need account for storing files.
- 533 FTP response code - Command protection level denied for policy reasons.
- 534 FTP response code - Request denied for policy reasons.
- 535 FTP response code - Failed security check.
- 536 FTP response code - Requested PROT level not supported by mechanism.
- 550 FTP response code - Requested action not taken: Permission denied
- 551 FTP response code - Requested action aborted: page type unknown.
- 552 FTP response code - Requested file action aborted: Exceeded storage allocation.
- 553 FTP response code - Requested action not taken: File name not allowed.
