Tools
FTP Clients
This article provides information about the most commonly used FTP clients for Serv-U
10/15/2018 6:45 PM
10/15/2018 6:45 PM
Here are the list of the most commonly used FTP clients for Serv-U:
  • FTP Voyager
  • FileZilla
  • CuteFTP
  • CoreFTP
  • FireFTP
  • WinSCP
  • Cyberduck (MAC)
  • SmartFTP
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
