Security Compliance
FS Logga not working
FS Logga for Windows file server does not work due to missing C++ runtime libraries
3/3/2020 3:02 PM
8/16/2022 4:09 PM
FS Logga for Windows file server needs an installation of filter driver and collector service on the Windows file server. The filter driver requires C++ runtime libraries that are suitable for the Windows version.
Access Rights Manager
The filter driver cannot be loaded due to missing C++ runtime libraries.
  • Verify ARM Service is working
  • Verify PNTracer process is running
  • On command line run "FLTMC FILTERS", look for MINITRC
  • On command line run "sc query minitrc", make sure it shows running
Please see also:
https://documentation.solarwinds.com/en/Success_Center/ARM/Content/prepare-windows-file-server.htm
  • Look at The PNTracer Log on the Collector Server
  • Search for "MINITRCUSER_ERROR_LOAD_MINITRCLIB"
  • If you see this error, install the required Visual C++ Redistributable on the fileserver with the collector.
Windows server versionRequired C++ Redistributable
2008 R211.0.61030.0 (Visual C++ 2012 Redistributable)
201211.0.61030.0 (Visual C++ 2012 Redistributable)
2012 R212.0.40660.0 (Visual C++ 2013 Redistributable)
201614.24.28127.4 (Visual C++ 2015-2019 Redistributable)
201914.24.28127.4 (Visual C++ 2015-2019 Redistributable)
  • Restart ARM Service on the collector
  • Disable FS Logga
  • Enable FS Logga
  • Check the PNTracer log file on the collector again.
  • Look for the error, if not found, look for: MINITRCUSER_ERROR_NO_ERR
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
