Security Compliance
Exchange unexpected powershell read error in ARM
This article explains how to mitigate an issue with PowerShell read error in the resources view in the ARM Rich client
6/9/2020 6:52 PM
11/5/2025 10:53 PM
Sometimes unexpected Powershell read error can appear in the resources view in the ARM Rich client.
In the related logs you can see the following:
  1. Couldn't find the public folder mailbox.
    CategoryInfo: NotSpecified: (:) [Get-PublicFolder], ObjectNotFoundException
  2. The operation couldn't be performed because '' matches multiple entries.
    CategoryInfo: InvalidData: (:) [Get-DistributionGroupMember], ManagementObjectNotFoundException
Access Rights Manager
This is related to the mailbox attributes.
Resolution 1
Please either restore or recreate the Public Folder Mailbox. If you don't have any Public Folder at all, just uncheck it from the Exchange Scan options in ARM Config---Scans.
Resolution 2
Some mailboxes may have the same Alias or display name. Please change them to be unique.
