Example NetFlow Config - Cisco 4500 Sup7
Example device netflow config for a Cisco 4500 with Sup7
10/13/2018 10:46 PM
10/13/2018 10:46 PM
This article contains an example device netflow config to export flow data from a Cisco 4500 with Sup7.
Netflow Traffic Analyzer
flow record ipv4
     match ipv4 tos
     match ipv4 protocol
     match ipv4 source address
     match ipv4 destination address
     match transport source-port
     match transport destination-port
     match interface input
     collect interface output
     collect counter bytes long
     collect counter packets long
flow exporter NetFlow-to-Orion
    destination 10.10.10.10 ( IP Address of the Solarwinds Netflow Collector)
    source vlan254
    transport udp 2055 (Collector port used by Solarwinds Netflow)
    export-protocol netflow-v9
flow monitor NetFlow-Monitor
  description Original Netflow captures
   record ipv4
   cache timeout inactactive 10
   cache timeout active 60
interface vlan254
ip flow monitor NetFlow-Monitor input
or
interface x/x
