Example Config - Extreme sFlow Configuration
This article contains a sample configuration to support Extreme devices.
10/13/2018 10:32 PM
10/13/2018 10:32 PM
Netflow Traffic Analyzer
The sFlow collector value must reflect the IP address of your NPM server. This value also contains the port number (2055) that is required in this step.
enable sflow
configure sflow config agent 10.199.5.10
configure sflow collector 192.168.72.67 port 2055
configure sflow sample-rate 128
configure sflow poll-interval 30
configure sflow backoff-threshold 50
enable sflow backoff-threshold
enable sflow ports all
