Example Config - Extreme sFlow Configuration
This article contains a sample configuration to support Extreme devices.
The sFlow collector value must reflect the IP address of your NPM server. This value also contains the port number (2055) that is required in this step.
enable sflow configure sflow config agent 10.199.5.10 configure sflow collector 192.168.72.67 port 2055 configure sflow sample-rate 128 configure sflow poll-interval 30 configure sflow backoff-threshold 50 enable sflow backoff-threshold enable sflow ports all
