Example Config - Extreme Networks IPFIX
This article contains a sample confirmation for Extreme Networks IPFIX.
configure ip-fix ip-address xxx.xxx.xxx.xxx protocol udp L4-port 2055 vr "VR-Default" configure ip-fix source ip-address xxx.xxx.xxx.xxx vr "VR-Default" configure ip-fix ports 47 ingress-and-egress enable ip-fix ports 47 ipv4 configure ip-fix ports 48 ingress-and-egress enable ip-fix ports 48 ipv4
