Evaluation is Ending. Purchase licenses to continue using key functionality
This article describes how to remove evaluation product versions for NCM and UDT. This needs to be done if the following message is displayed advising that Evaluation products are expiring or have expired: Evaluation is Ending! Purchase licenses to continue using key functionality.
The following message is displayed advising that Evaluation products are expiring or have expired:
- Go to Control Panel and uninstall NCM, NCM-NPM integration, UDT, and any other evaluation products displayed in the message. An example of an integration module is listed as SolarWinds Orion NCM-NPM Integration v7.5.1.
Note: See the Unable to uninstall NCM evaluation product version article if the integration module is not listed in the Control Panel. - If the configuration wizard starts to install the products, click Cancel. Run the wizard only after they have been uninstalled.
- Confirm that the Evaluation products are no longer in License Manager.
You would perform the same steps for ANY products that are showing as EVAL and you want to remove those entries from your manage license page.
