"Error while executing script- The index 'RouterNodeID_Includes' is dependent on column 'FirstSeen'." error in Configuration Wizard during upgrade to SolarWinds Platform2025.4
This article provides information about an issue where running the Configuration Wizard during an upgrade to SolarWinds Platform 2025.4 fails with a database configuration error.
During an upgrade to SolarWinds Platform 2025.4, the Configuration Wizard may fail during the database configuration phase. The following error is displayed:
SolarWinds® Platform Database FAILED
Database configuration failed:
• Error while executing script- The index 'RouterNodeID_Includes' is dependent on column 'FirstSeen'.
ALTER TABLE ALTER COLUMN FirstSeen failed because one or more objects access this column.Product section
The error occurs because an index is dependent on a column being dropped during the upgrade script execution.
Run the query below against the SolarWinds database using SQL Server Management Studio. Before proceeding, ensure that a current backup of the database is in place.
-- Drop the dependent index if exists
IF EXISTS (SELECT name FROM sys.indexes WHERE name = 'RouterNodeID_Includes' AND object_id = OBJECT_ID('dbo.UDT_IPAddressCurrent'))
BEGIN
DROP INDEX RouterNodeID_Includes ON dbo.UDT_IPAddressCurrent;
END
Run the Configuration Wizard again and ensure it completes successfully.
