Configuration Wizard fails with an error "Error while executing script- Database and server triggers on DDL statements CREATE, ALTER and DROP are not supported with memory optimized tables."
Getting an error in CW and this error isn't specific to a Product Version: ERROR TaskAdapter - Error running task Orion.ConfigureDatabase SolarWinds Platform Database SolarWinds.ConfigurationWizard.Common.ConfigurationException: Error while executing script- Database and server triggers on DDL statements CREATE, ALTER and DROP are not supported with memory optimized tables.
6/17/2025 8:29 PM
6/28/2025 9:02 PM
When you upgrade the SolarWinds Platform, the Configuration Wizard fails with an error:
Note:
This error can occur during a SolarWinds platform upgrade and is not specific to any particular version. It may arise during any upgrade process, regardless of the version being used.
Orion Platform
This issue occurs due to the following reasons:
  • Cannot create memory optimized tables due to a possible Microsoft SQL Server 2022 bug
  • The feature 'EVENT NOTIFICATION' is not supported with memory optimized tables. "Memory-optimized tables and natively compiled stored procedures cannot be created or dropped if there is a server or database event notification for that DDL operation. Remove the server and database event notifications on CREATE TABLE or DROP TABLE and CREATE PROCEDURE or DROP PROCEDURE." For more information, refer to the following document.
  • Custom SQL triggers enabled on memory optimized tables. For more information, refer to the following document
Make sure we have a backup of the Database before executing any scripts:
  1. Search for the Tables with Triggers
    SELECT * FROM sys.triggers WHERE parent_id = 0 or Name like '%DDL%' -- or
    SELECT * FROM sys.Server_triggers WHERE parent_id = 0 or Name like '%DDL%'
  2. Run the script below replacing the [TriggerName] with the name of the Trigger
    DISABLE TRIGGER [TriggerName] ON DATABASE;
  3. Run Configuration Wizard again as administrator.
